Error No 2
Hey guys i am trying to load a 5.1 Labview application into 6.0 and it keep giving me this error
"Unable to load CMSDRV Error No 2"
(3,521 Views)
Try closing all other applications, it looks like you may not have enough memory available to load the whole thing.
(3,521 Views)
You know when i upgrated my labview 5.1 to 6.1 that is when i start having this problem.
The wierd part is that my aplication is working fine in labview 5.1 on 6.1 if gives an error.
(3,521 Views)
Could you attach the VI that is causing the problem? I don't know what CMSDRV is but could it be a CIN or .dll that's not part of LabVIEW 6?
(3,521 Views)
Here is the main file
If you need any others let me know
Thanks.
(3,521 Views)
I can't load it into 5.1 or 6 because you didn't attach the .llb for the whole program. There are VIs missing. It appears that it is calling some acquisition VIs that are not part of LabVIEW 5. If you are using non-NI hardware, the problem may be in the driver for it. Either it's not installed on your system, it can't be found by LabVIEW 6, or the driver has some VIs without a diagram. If there is no diagram, you won't be able to convert from 5 to 6. If you want to attach the main with all subVIs, go to save with options and choose Development Distribution.
(3,521 Views)
