Error Message: Code could not be generated successfully for the VI
I created a simplified model of an 8-pole DC servo motor with friction brakes that drives an actuator through a gear train. I can't get past the subject error message. The error is about the VI named ""Sermat 3-Phase 8-Pole Motor with Friction Brake"" in the package attached. One thing I noticed is that when I make any minor modification to this VI, even a trivial one (like multiplying a signal by a gain of one, or changing the value of a gain from a to b) the VI stops complaining for a while and simulates/runs well. But as soon as you close the VI and open it up again, it goes back crazy on you again.
I appreciate if someone can guide me as to why this happens an what am I doing wrong here. Appreciate the help :-)!
Akif
Message 1 of 1
(2,543 Views)
