Error List as txt file
I have written a DLL for comunicating with a serial device. The problem is, that error messages can only be transfered as error code, which is not very meaningfull. With a text list of error codes with explanations it would be possible to generate an error messages. Does anybody know if such a list exists?
EPH
Message 1 of 17
(4,040 Views)
Hi eph,
just look at the functions in the Dialog & UI functions palette. After reading the help for each of them you create your own error code descriptions
Message 2 of 17
(4,039 Views)
Thank you for the answer, but this doesn't help. I do not want to create a list, because there are several error codes and this would take much time. My question was, if this list is already there, in LV or in the web/forums.
EPH
Message 3 of 17
(4,030 Views)
Hi EPH,
how can there be a list for your DLL written by you? It's your DLL, so you have to create that list…
Message 4 of 17
(4,023 Views)
I don't want to create new error codes.  It is that my DLL comunicates via VISA with the serial port. And therefore some of the VISA-errors might occur. I send this error codes to the application, that uses the DLL. And at this point I want to generate a text message instead of "code -107...."
To make it clear: I want to use the build-in error codes.
EPH
Message 5 of 17
(4,010 Views)
Sounds like you want to use Error Cluster From Error Code and then use the General Error Handler.
Message 6 of 17
(4,008 Views)
No.
What I am searching for is a list like the following:
-107.....     Port doesn't exist
-107....      Port in use
-107....
EPH
Message 7 of 17
(4,006 Views)
Hi EPH,
either copy the LabVIEW help or vreate your own list like this:
Message 8 of 17
(4,001 Views)
Hello GerdW,
that might help, thank you. But I have supposed, that such a list exists in LV.
EPH
Message 9 of 17
(3,998 Views)
Hi EPH,
the LabVIEW help lists all error numbers. You just need to read and copy the help…
Message 10 of 17
(3,990 Views)
