Error Inserting .NET
I am using LV 2013 32-bit. I am getting an error trying to insert a .NET file. Attached is the error. This VI was working fine until I moved it to a different location and tried to make it a class, so I think that caused the issue, but I'm not sure where to start. Attached is also my VI. I am using the ThorLabs DCServoKCube controller. The .dll file is the Kinesis Control.dll.
Thanks for any help,
SM
(4,246 Views)
Hey Sman29,
Where was the file moved to? Also what was the process that you used to make the VI into a class?
(4,153 Views)
It was just moved to a different file on the desktop.
The process I used to make a class is just create a new class in the project manager and then pull my stand alone VI's into the class and integrate.
SM
(4,141 Views)
If you move the VI's back to the original spot do you still recieve the same error?
(4,134 Views)
I cannot move them back as my dependencies and files get all messed up in my project. Plus, they are classes now so putting them back in the original file (which no longer exists) wouldn't really do anything, would it?
SM
(4,132 Views)
