Error Hex 0x4076
I am trying to use the example: "email with data.vi" .  I put as the server the gmail SMTP (smtp.gmail.com) but when I run the program appears the following message: (Hex 0x4076) 502 Command not implemented. Does anybody can help me?
Thank you very much
Message 1 of 9
(4,352 Views)
Hey Rafo.
Which version of Labview do you use?
Could you attach a screenshot of your error please?
Regards.
Romain D.
National Instruments France
Message 2 of 9
(4,327 Views)
Where did you find this example? You should be aware that gmail uses SSL encryption, so most likely that's your problem.
Message 3 of 9
(4,316 Views)
I'm having the same problem and I've attached the screen shot of the error message here.
Thanks for all your help.
Message 4 of 9
(4,225 Views)
Your screenshot doesn't appear.  You need to post the screenshot as an attachment to your message before you insert an image link.  The image that you posted points to your hard drive which of course we don't have access to.
Also, please don't post a .docx file.  Most people don't have whatever program is required in order to open that.
Message 5 of 9
(4,214 Views)
Here is that file he had attached actually...
Its a zip file
Mathan
Message 6 of 9
(4,179 Views)
The file was accessible, and there's a screenshot in the file. The problem is that it's in Word 2007, and not everyone has Word 2007. Even if you have Word 2003 you need to download and install a translator to see it, and it should be the poster's responsibility to put a screenshot that everyone can see, like a PNG or JPEG, not our responsibility to install a translator to see a screenshot that's emdedded in a Word 2007 document.
Besides, the question I asked still remains, and the OP never responded, so I pose the same question to the new poster.
Message 7 of 9
(4,160 Views)
Is this error ever resolved?
I am trying the same vi and get the same error message.
I am using LabView 7.1
Please help on this error.
Thanks.
Message 8 of 9
(3,738 Views)
Please see this discussion : http://forums.ni.com/ni/board/message?board.id=170&thread.id=160692&view=by_date_ascending&page=1
and the following KB : Why Do I Get Errors with the SMTP Email VIs?
Hope this helps.
Steve M.
Message 9 of 9
(3,690 Views)
