Error Handling Question
How does everyone handle errors when a error comes across as OK(error number)? I notice that my error case structure does not handle what I think are "soft errors", for a lack of the correct term, but I want to take some kind of action on those kind of errors.
What is the trick that I am missing? Is it as simple as taking a Unbundle by Name and wiring the error number to the case structure and eliminate wiring the error cluster directly to the case structure?
(3,629 Views)
Hi Eric,
I think you are talking about "warnings"…
You can use an Unbundle function to get the 3 components of the error cluster…
(3,627 Views)
Just so I do not look like a fool...like this?
(3,620 Views)
Hi Eric,
can you attach a downconverted version of your VI? I'm stuck at LV2017 right now…
(3,611 Views)
(3,606 Views)
Accepted by topic author Eric1977
No.  Errors have a True boolean value.  Warnings and non-errors have a false boolean state.
So you should have a NOT on that top boolean wire going to the AND.
(3,605 Views)
