Error Connecting DL3021 electronic load to Labview; Error code - 1073807331
Dear experts,
I am trying to connect the DL3021 electronic load to my Labview (v. 2021 SP1) program but encounter problems with the connection of the device. The program is given within the attachments. If I try to connect as this:
I got the following error:
This means there is an error when connecting it with the DL3021. Is there a way to fix this problem?
I tried to control the device within the VISA test panel from NI MAX and this gave no problems. I was able to control the device and read out the relevant data. It is specifically an error coming from LabVIEW. The software I have can also be seen in the attachments displayed in NI MAX. NI VISA is installed as can be seen.
I would like to hear from you if you need more information to tackle this problem.
With kind regards,
Iljar Dickhof
Message 1 of 1
(882 Views)
