Error Code -17502
I hope someone can help?
We have TestStand 2.0.1 and Lab View 6.1 running on Windows 98.
We recently added a LabView function to extract directories and there files (the attached LabView code).
We but in at the start of the test sequence to check its functionally and it worked but once it is its correct place it returned a run time error (-17502)
After a lot of shifting the LabView section around we found, at least, the error would occur after we run a GPIB command.
The GPIB command is run via a DLL getting its input from a text file.
The same DLL and text file are used for other functions and do noe effect the LabView module.
Can anyone provide some help or direction on the LabView code?
I am posting in both TestStand and LabView discussion forms in the hope that some help might come!!!
Thanks for the help
Simon
(3,176 Views)
Duplicate post.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,141 Views)
