Error Code 1003 when running exe - need help
Have a VI that I run and the below code executes and calls the sub vi but when I build it as an executable I get an error message 1003, can anyone help?  It is part of a bigger VI but this is the only part that is failing.
I have included the sub VI in my exe build as "always include" and the sub VI is in the same directory as the main VI that calls it.
Regards
Martin
(2,036 Views)
Hi Eaton,
Why do you call the VI located in that "Andon" folder instead of the VI located in your executable?
(That folder should probably named "Addon"!? 😄 )
Does that VI reference any dependencies? Does your executable know about those?
Why don't you call the subVI by placing it in your block diagram? Do you really need to use VIServer to call it?
(2,030 Views)
Hi GerdW,
I am calling the sub VI this way as it basically plays a sound every 15 seconds until it is closed by the user and therefore I loose functionality in the main VI as it is waiting for the sub VI to finish.
Not sure I understand the question here sorry?
I think the only dependency is related to playing the sound and when I look in the project dependencies the "play sound" is in there?  Like I said the project lists the sub VI in always include?
Thanks for the help.
Regards
Martin
(2,019 Views)
Hi Eaton,
It will only block the main VI when you don't call that subVI in a loop running in parallel…
(2,012 Views)
