Error But Want Exit Code To Still Run
I have code that will uses the error in and error out cluster method of handling errors.  If there is an error I want my exit code to still run but it does not because the error cluster is wired to the exit code.  What is the best way to handle an error in the error cluster but still run the exit code?  Thanks!
(3,390 Views)
Hi testdesign,
just run your "exit" code independently from the "error in" state:
(3,388 Views)
You could use the Clear Errors VI prior to calling the exit code:
I hope this helps,
Charlie Rodway | Principal Software Engineer | Certified TestStand Architect (CTA)
Computer Controlled Solutions Ltd | NI Silver Alliance Partner | GDevCon#1 Sponsor
(3,165 Views)
