Error: An internal error occurred for which the cause is unknown. (Error code -
I'm getting an error message, ( Error: An internal error occurred for which the cause is unknown. (Error code -41)) when I try to build an installer that includes two other .vi's that have already been built. I found some information on another forum for CVI and it stated there there was probably a particular add-on/product that wasn't up to date and to create a log file to show a NI developer in order to know what needs upgraded. Unfortunately, I can't figure out how to create the log file in LV8.5, the instructions were for CVI. Can somebody tell me how I should proceed?
(3,272 Views)
Thanks for posting your question.  If you see a pop-up window that gives you the option to investigate this internal error, make sure you choose "investigate later", and note the location that the log file is saved to.
In case we are unable to obtain the error log file, I have some questions for you.  What addons or toolkits are you using in your project?  What versions are they?  Are you using DAQmx and if so, what version? When you create an installer for another project do you receive the same error, or is it only this specific project?  Is there anyway that you could post your project and I could attempt to reproduce the error on my machine?  Any information would be helpful in troubeshooting this error, thanks!
(3,254 Views)
