Error: An input parameter is invalid
I got a vi file from my friend.
When I try to open it, I got about 20 error messages, and one is like following.
"LabVIEW: An input parameter is invalid. For example if the input is a path, the path might contain a character not allowed by the OS such as ? or @.
The file 'DAQmx READ (Analog 1D Wfm NChan NSamp).vi' could not be loaded."
But I am sure that there is no character like ? and @ in the path.
Other error messages are very similar and only the film name of last sentence were changed.
- The file 'DAQmx Creat Channel (CO-Pulse Generation-Frequency).vi' could not be loaded.
- The file 'DAQmx Timing (Implicit).vi' could not be loaded.
..... and so on.
What should I do in order to resolve this problem?
And when I open the file, I could see that many words are broken.
Thank you.
(7,938 Views)
Accepted by topic author kjh2677
The first thing that comes to mind is : Have you installed DAQmx?
Ben64
(7,930 Views)
Thank you for your answer.
Actually, I am a beginner of this field.
https://www.ni.com/en-us/support/downloads/drivers/download.ni-daqmx.html#325032
Will downloading this solve the problem?
Thank you.
(7,919 Views)
