Error 97 using Active-X property node
One other thing I forgot to mention...  You have to insert a control into the container (via the front panel) before you'll see the "Create>>Property>>" and "Create>>Method>>" choices in the container's context menu (on the block diagram).
George Erwin-Grotsky
LabVIEW Research & Development
Message 11 of 13
(1,848 Views)
Before I reopened the thread I have made a screenshot of what I have done, but you have described it with words. I will post it here. I have choosen the property of the object from the terminal in the BD. I have learned that LV has a differrent behaviour in the property node for LV objects and Active-X objects.
The FP context menu is the same in LV 8.0 as in LV 7.1. You can also only choose Create >> Property Node Create >> Property is missing.
Message Edited by waldemar.hersacher on 03-09-2006 09:41 PM
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
Message 12 of 13
(1,847 Views)
Hi
Getting Error 97 from invoke node 'Openschema'.
Please help me resolve this issue...
Message 13 of 13
(1,333 Views)
