Error 89120 - Swept Sine
G'day
I have a NI USB 6259 connected to a power amplifier and shaker through AO0. I have downloaded the swept sine VI from the NI website to go with the sound and vibration toolkit.
However when I run this VI even though I have slected my A0 excitation channel : Dev1/ao0 the program shoots out the error message:
Error -89120 occurred at SVT Start Swept Sine (DAQmx).vi
Possible reason(s):
Source terminal to be routed could not be found on the device.
Make sure the terminal name is valid for the specified device. Refer to Measurement & Automation Explorer for valid terminal names.
I have attached screen shots of the program and MAX
Your help is most appreciated
Regards Tanju Yildirim
(3,091 Views)
These are the attached files dont know why the previous message wouldn't post them
(3,090 Views)
Tanju,
A few quick questions:
First, what version of LabVIEW are you using? What Operating System? Is your S&V toolkit up-to-date? Where did you download the Swept Sine vi from, specifically?
Kirk L. | Applications Engineer | National Instruments
(3,039 Views)
I had an older version running with the USB device however I deleted the trigger line in SVT start sine sweep which fixed the problem.
Thank you for replying however
Regards Tanju
(3,030 Views)
