Error -8000 XNET Close Diagnostic
Hi, I have a problem with the „Close Diagnostic.vi“ (Automotive Diagnostic Command Set) after requesting an empty event memory with "UDS ReportDTCByStatusMask.vi“. This leads to the error -8000 -> NI Automotive Diagnostics Command Set: The handle passed to the function is not valid.
After closing the VI LabVIEW freezes. Maybe the XNET background is hanging up?
(4,965 Views)
it seems that you lose the reference somewhere in your application.
Could you provide your code to have a closer look?
Best wishes
Work with NI Hard- and Software for about 15 years now.
Certified LabVIEW Developer & TestStand Developer/Architect
(4,919 Views)
If there is no DTC, the "False" case isn't executed, but unfortunately Labview hangs up during closing.
(4,912 Views)
Accepted by topic author TiBr
That close should probably be outside of the case structure.  What if there is no DTCs?  Then you never close your reference?  Opening a reference and never closing it could lead to memory leaks.  I think regardless of how many DTCs you have, you should close that reference before leaving that subVI.  For every open call, you should execute a close.
(4,908 Views)
Damn, this seems to be the solution! Thanks Hoovahh!
(4,905 Views)
