‎08-18-2010 07:26 AM
‎08-18-2010 07:31 AM
No attachment 😞 If an image, remember .png NOT .bmp Thanks!
‎08-18-2010 07:35 AM - edited ‎08-18-2010 07:36 AM
‎08-18-2010 08:00 AM
This error message has many causes so check the following:
Check File Permissions to see if they are read only
Make sure you logged in as Admin
VIs need to be in the same version of LabVIEW
‎08-18-2010 08:05 AM
‎08-18-2010 11:32 AM
Strange indeed..
Some more questions to find out about your envirnoment:
Do you always log in using the same username? (probably)
Do you do anything to the code between re-starting the computer and being able to compile (or not being able to compile)?
How many versions of LabVIEW are installed on that PC?
Are there multiple users sharing the same PC (with different or same login)?
‎08-19-2010 01:13 AM
‎08-19-2010 09:37 AM
Wow.. that IS a strange one.
LabVIEW 7.1 was (still is) one of my favorite version for stability.
I'm not sure what to suggest other than contacting NI support, giving them your code and letting them play (compile) with it to see if they can reproduce the problem.
‎08-19-2010 10:12 AM
