Error 8 Open/Create/Replace File in Write Spreadsheet String.vi->Write Delimited Spreadsheet (string).vi->Edit Calibration.vi
Hi All,
I get an error code 8 when I try to run and save my program. I tried to highlight execution and add probes but it doesn't fail until the last write delimited spreadsheet.
Basically, the program updates a .cal file containing a control number and calibration date like this:
I can't add a .cal file to the forum because it isn't supported. It also need a Test Setup Files folder and a IR AC DC.cal with this example:
Would anyone know what is happening?
Thank you,
TK
Message 1 of 13
(4,392 Views)
Hi Teekayy,
Try: Closing LabVIEW completely and run it as administrator. Then try to write to file.
Message 2 of 13
(4,384 Views)
Accepted by topic author Teekayy
You can attach any file you want if you zip it.
Works fine for me. Could be a permission issue in the write location. Are you running in the development environment or as built executable?
(did you know that index array is resizable? I don't think your program is bulletproof because your flattened timestamp could easily contain a tab character as part of the binary string, which would then corrupt the reading of the timestamp)
Message 3 of 13
(4,378 Views)
Hey XM43,
I can't run it as  administrator because I don't have access from my company and it requires elevation.
Would there be any other way around this or any other solutions?
Thank you,
TK
Message 4 of 13
(4,375 Views)
Hi altenbach,
Ahh I didn't think about that haha. I am running it in development environment. It could be a permission issue..
TK
Message 5 of 13
(4,372 Views)
You can move the file or create a copy to "C:\Users\Public\Documents" and then try to see if you can read it from there. If you are still not able to read it, then the file itself has permission restrictions.
Message 6 of 13
(4,347 Views)
As I said, your current technique is dangerous. You need to either use a fully binary file or format your timestamp using readable characters.
Message 7 of 13
(4,346 Views)
Thanks altenbach,
Whoops haha I didn't realize in the properties of the .cal that the read-only box was checked.
Ah I see... you need to either use a fully binary file or format your timestamp using readable characters. Okk thanks Ill keep that in mind
Kind regards,
TK
Message 8 of 13
(4,341 Views)
Here's one quick draft. I am sure it needs a few tweaks...
You probably want to write some special sentinel values to the data control if the calibration file does not exist, or handle as error (not shown).
Message 9 of 13
(4,292 Views)
Oh thank youu.
Would you suggest I change my Retrieve and Check Calibration then?
to
Message 10 of 13
(4,269 Views)
