Error 74 in unflatten to string
The attached VI opens a file in read\write mode. If the file doesnt exist it creates a file. The next time when the vi is run the created file is read. If the file already exists then it only reads the file. The data is a cluster which is converted to binary using flatten to string function and then written to the file using write binary file function. When I read back the file, I get the error 74.
My observation :  The flatten to string output is different from what it is written to the file. Some special character is added to the starting of the file.
But i dont face any problem when i replace the read binary file or write binary file with the read text file and write text file respectively.
Regards
Gopal
(6,239 Views)
The "Write to Binary File" VI has an input "prepend array or string size". Wire a False to this input and your VI will work as expected.
Side note: You seem to be relying on the "Automatic Error Handling" in LabVIEW. I would recommend not doing this, and following the convention of having an error in/error out cluster for VIs. In your VI any error that gets generated is not being passed out.
(6,226 Views)
