Error 7 when opening a VI reference from within a .exe
Maybe someone can tell me why I get Error 7 (LabVIEW 2011 SP1 project included). I can get it to work if I remove the first directory ("Controlled Software") in the path string (block diagram of "Main Menu.vi"). I fail to understand why this directory is ignored when trying to open a VI that is in that directory hierarchy. I have it as "Always Included" in the build properties (Source Files).
(2,839 Views)
Why Does My Executable Not Work When Using the Current VI's Path Constant?
Basically, the same problem.
Put indicators on your paths and you'll see the problem.
(2,817 Views)
