Error 7 when compiling (Labview 8.2)
When I try to compile my code into an EXE I Get this Error:
Visit the Request Support page at ni.com/ask to learn more about resolving this problem. Use the following information as a reference:
Error 7 occurred at Invoke Node in ABAPI Get Library Reference.vi->ABAPI Load All Libraries And VIs.vi->ABAPI Dist Build LLB Image.vi->ABAPI Copy Files and Apply Settings.vi->EBEP_Invoke_Build_Engine.vi->EBUIP_Build_Invoke.vi->EBUIP_Build_Invoke.vi.ProxyCaller
Possible reason(s):
LabVIEW:  File not found. The file might have been moved or deleted, or the file path might be incorrectly formatted for the operating system. For example, use \ as path separators on Windows, : on Mac OS, and / on Linux. Verify that the path is correct using the command prompt or file explorer.
NI-488:  Non-existent board.
Method Name: Library:Open
I have tried to mass compile and that didn't work.
It compiled fine before.  All I did is add a read file vi to my code.  I tried taking out the new code and same results.
Any Ideas?
Glenn Ellis
(3,274 Views)
I have no experience with the 8.x app builder, but this probably means that the builder has some file listed somewhere which it can't find. I suggest you simply try creating the build from scratch.
___________________
Try to take over the world!
(3,261 Views)
Hey glennjammin,
    There are a couple of possibilities for this error.  A few customers have reported in the discussion forums that they had success just deleting that build and creating a new one.  Also, if you have shared variables that are contained within a subVI, that can lead to this issue.  Perhaps try slowly adding parts of your VI to a new blank VI until the build breaks, that would help point us in the direction of the issue.
Brian B
Account Manager
(3,244 Views)
Smiley Very HappySmiley Very Happy
I finally fixed it!  For some reason Labview decided it can't find a vi I was using to control an instrument even though it was there.  I Copied the vi from a different folder and replaced the vi in my diagram and it worked.
It was very annoying that Labview didn't specify which vi it was having a problem with.  Error 7 seems to be a catch all.
I spent way too much time on this stuped error.
Thanks for all the replies though.
Glenn
Glenn Ellis
(3,223 Views)
