Error 7 occurred at Invoke Node in Dist read linkages.vi->Dist Cmp Settings to Disk Hier.vi->Build Application.vi
Error 7 occurred at Invoke Node in Dist read linkages.vi->Dist Cmp Settings to Disk Hier.vi->Build Application.vi????
Hi I do not understand how to resolve this nagging problem.
I run the program in the development time and it all goes smoothly.
However when i wanted to build the program. I often run into this problem.
How to resolve it?
Clement
(3,298 Views)
Hey Clement,
Which version of LabVIEW are you using? There some knowledgebases out there that address the issue. Click here for the first KB or here for the second one. Hopefully these would help.
Chetan K
Application Engineer
(3,281 Views)
Thanks. I am using Labview 7.1. I just realise that I have attached the web page to documentation, when trying to build application. I just removed the webpage and it works. Will try to investigate why it happens. Any way thanks.
 Clement
(3,268 Views)
