Error 63044:The RIO server could not be found on the specified remote device.
Hello;
I am using for the first time an FPGA application on sbRIO 9627 ; at the beginning  I'm trying to confirm successful communication using very simple VI.
It compiles and generates FPGA Bitfiles but when run an error 63044 is shown in the attached screenshot.
I am running Labview 2017 on Windows 10 and my device as mentionned is  sbRIO 9627.
your help will be very appreciated.
(2,952 Views)
Hello Karim_Eng,
Do you have the correct version of NI-RIO server in your sbRIO? Maybe a reinstallation would solve the problem.  This document from NI could be helpful:
http://www.ni.com/getting-started/set-up-hardware/compactrio/controller-software
(2,908 Views)
yes the reinstallation of the NI-RIO  solved the problem and it runs correctly now.
Thank you for your help.
(2,902 Views)
