Error 63 occurred at TCP Open Connection in Segger RTT TCP Client.vi
I am interacting with the Segger RTT interface via TCP. Upon ESTABLISHING a connection, they spawn another LISTENER. I am able to indefinitely telnet to 127.0.0.1 19021 and create new connections:
0
C:\cmder λ netstat -an -p tcp | findstr 19021 TCP 127.0.0.1:19021 0.0.0.0:0 LISTENING
1 C:\cmder λ netstat -an -p tcp | findstr 19021 TCP 127.0.0.1:19021 0.0.0.0:0 LISTENING TCP 127.0.0.1:19021 127.0.0.1:60132 ESTABLISHED TCP 127.0.0.1:60132 127.0.0.1:19021 ESTABLISHED
2 C:\cmder λ netstat -an -p tcp | findstr 19021 TCP 127.0.0.1:19021 0.0.0.0:0 LISTENING TCP 127.0.0.1:19021 127.0.0.1:60132 ESTABLISHED TCP 127.0.0.1:19021 127.0.0.1:60155 ESTABLISHED TCP 127.0.0.1:60132 127.0.0.1:19021 ESTABLISHED TCP 127.0.0.1:60155 127.0.0.1:19021 ESTABLISHED
In the LabVIEW vi, TCP Open Connection only works in case `0` above, which is when no connections are ESTABLISHED. In cases 1 and 2, I get Error 63:
Spoiler
Error 63 occurred at TCP Open Connection in RTT TCP Client.vi
Possible reason(s):
LabVIEW: Serial port receive buffer overflow.
LabVIEW: The network connection was refused by the server.
How can I get LabVIEW TCP Open Connection to behave more like telnet and find the LISTENER?
Cheers,
Joe
(4,477 Views)
Further testing shows that there is a maximum of two connections no matter what application attempts to connect. LabVIEW only works for the first connection.
(4,470 Views)
Upon "Close TCP Connection" in LabVIEW it results in these states (CLOSE_WAIT and FIN_WAIT_2):
C:\cmder
λ netstat -aon -p tcp | findstr 19021
TCP 127.0.0.1:19021 0.0.0.0:0 LISTENING 1656
TCP 127.0.0.1:19021 127.0.0.1:60938 CLOSE_WAIT 1656
TCP 127.0.0.1:19021 127.0.0.1:61013 ESTABLISHED 1656
TCP 127.0.0.1:60938 127.0.0.1:19021 FIN_WAIT_2 8148
TCP 127.0.0.1:61013 127.0.0.1:19021 ESTABLISHED 11860
Same occurs with Telnet. Not finishing closing the connection may be a Segger issue.
(4,468 Views)
