Error -61046 Using When Compiling FPGA Code That Uses External Clock
Hello Sir, i'm beginner of labview.
i'm using PXIE-7820R.
i want to receive an external clock signal( 10MHz /1pps) from  clock generator.
So i connect  PXIE-7820R connector pin( external output) with generator.
and also i  used   External clock example in NI.,
But it is not working... with Error -61046.
i submit example vi that i used.
Thank you sir!
(760 Views)
Are you working on the same project with Michol? A similar question has been asked in Re: PXIe-7820r, Octoclock External clock 10MHz Synchronization
https://tmesystems.net/
(732 Views)
