Error -52005 Current Sense NI 9208
Hi All,
I'm experiencing an error (52005) while trying to sense current with a NI 9208 (and NI 9181 ethernet 1-slot cDAQ chassis). What's strange is that DAQ assistant worked fine for multiple days before randomly not working (no changes to hardware/software). I decided to recreate the code with the daqmx api and I'm still getting the same error code. I'm able to communicate with the cdaq module via NIMAX and obtain measurements. No luck though in the LabVIEW environment. Any suggestions or ideas?
First code - once stable:
Second code using daqmx:
Thank you.
-Corey
Message 1 of 1
(634 Views)
