Error -50405
Hi everyone,
I have one cDAQ 9188 chassis and I am using Labview version 16.0f5(64-bit). The labview program contains DAQ Assistant and once in a while I get error -50405 and as a possible reason, it says "No transfer in the progress because the transfer was aborted by the client". Sometimes it works for half an hour without any error, but sometimes the same error window appears every 2 minutes.
Any help or suggestions would be appreciated.
Thanks in advance.
Deniz
(3,357 Views)
The problem is either Hardware, Software, or (possibly) bad wiring.  We know you have a cDAQ 9188, but no idea what modules you are using (because you didn't tell us),  We know you are using 64-bit LabVIEW 2016, but no idea what other modules or drivers you are using (because you didn't tell us).  We know you used DAQ Assistant, but don't know what you asked it to do, nor how its use fits into the rest of your LabVIEW code (because you didn't attach your code).
If you want more help, you need to "help us to help you".  If I had to guess, I'd guess that the problem is probably Software.  If you want suggestions on what to fix, attach a Zip file containing your LabVIEW Project and all relevant VIs and attach it to your reply (don't send "pictures" of your code -- we can't examine, edit, or test a picture).
It also wouldn't hurt to give us some idea something about what you are trying to do with this code.
(3,305 Views)
