Error 37 using serial port with an executable file
Hi all,
I have developed a VI that controls a setellite receiver using RS232
serial port (LabVIEW 5.1.1).
The VI program run properly, but when I compile it and try to run the
executable file I receive an "Error 37, Device not found" error message.
I have already put serpdrv and my_file.ini files in the same directory
of my executable program my_file.exe, but I have not been able to solve
the problem.
Any help greatly appreciated.
Regards
Antonio
Sent via Deja.com http://www.deja.com/
Before you buy.
(3,096 Views)
antomoz@my-deja.com wrote:
> Hi all,
> the problem.
> Regards
> Antonio
> Before you buy.
Maybe you used the serpdrv from an older version of LV
Regards, Roland
Roland Lampka - Nortel Dasa - ESN 565-7257 - FAX 8160
(3,096 Views)
