Error 363507 : LabVIEW could not verify the authenticity of the server.
i am trying to configure a HTTPS connection using HTTP client VIs.
I am using Configure SSL.vi, I have a .cer file (certificate) which I am     connecting to CA Certificate file input and then using a HTTP POST method vi to send a POST request.
Configure SSL vi does not return an error however, HTTP Post method vi returns an error:
Error 363507 occurred at LabVIEWHTTPClient.lvlib:POSTFile.vi:3390001
Possible reason(s):
LabVIEW:  LabVIEW could not verify the authenticity of the server.
Complete call chain:
I have tried requesting with Verify Server input as True/False but response is same
Please advise if the sequence is correct? Also how can I use configure SSL vi to use the certificate file provided
Message 1 of 1
(3,467 Views)
