Error 363500 Failed to connect to the specified hostname
I'm trying to send an email using the VI example but i have a problem with de connection to hostname.
Someone that already worked with this VI?
(1,815 Views)
It looks like gmail's outgoing mail server is smtp.gmail.com not smtp.google.com as you have in your code.
https://support.google.com/mail/answer/7126229?hl=en-GB
If that doesn't work I would suggest posting your actual code so we can see exactly what you have done. Remember to remove your passwords before posting on here though!!!
(1,779 Views)
