Error -314004 can not connect to cRIO 9074 but can debug and see shared vars do I need to generate a configuration file
I try to connect to a Ni 9074. I am having a hard time doing this. I did try to do most of what's described in this link:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019R3TSAU&l=nl-NL
  1. I can ping the 9074. I can ftp into the 9074 and see the log files are changing.
  2. Debug seems to work. I start debug with clicking: operate -> debug application in the menu of the project explorer.
  3. I start the UI main on my pc with hitting the run button. I did disable auto-deploy because else it tries to deploy the target on the cRIO also.  I did take a look at my pc IP adres with cmd ipconfig and copied the IP to my-computer in the project explorer.
  4. With MAX I did check if the network stream software is installed and it is there.
  5. I can connect to shared variable lib with the UI main running on my pc, the shared vars use the same IP as the network stream.
  6. When I run procmon64.exe I use a filter:  "eventclass is network include." this shows there is data transfer between the cRIO and the PC. I can not see any packages being dropped. Dont know if this would be the exact text though if a port is blocked.
  7. I did just update the cRIO from Labview  2016 to LV2018 with MAX I can see the same software which was installed on the LV2016 version is also installed on the LV2018 version (of course with other version numbers)
When I read the link above I get the impression I need to make or edit a config file. I did search for It but I could not find it. Could this be the reason I do get Error -314004  ?
Hope you can help, thanx
(1,738 Views)
Update:
I did check the CPU load with Ni distributed system manager and I can see the Normal priority is 97 or higher all the time.
I did close the debug connection with the cRIO and I did manage to connect one time. But then the shared vars were giving an error. I will try to find which loop is causing this behaviour.
Is there a kind of systemmonitor for the cRIO which can pinpoint more accurate ? like top in linux? This cRIO uses VxWorks btw
(1,700 Views)
I think I might be doing something wrong with deploying the code to the cRIO.
I do a build, clicking the build file -->  right mouse --> build
Then I click the build file to deploy. when I deploy I get a message telling me
the target is already running a real time application I can click okay then it deploys. The CPU load drops so I know the new build is running (I did put a wait in the loop receiving messages from the message stream of 50 ms it was 1ms). when I reboot the cRIO hitting the reset button the CPU load is high again. This makes me think a old build runs after I hit the reset button. There is also a switch on the cRIO telling me "No APP". As there are a lot of things that might go wrong can someone please tell me if I need to use the "No app switch" ? Or give a general direction how to fix the network issue. I think I need the lower CPU load to connect to the cRIO to start with.
(1,686 Views)
Can you share your code? It's extremely hard to troubleshoot without code.
(1,669 Views)
Hello adekruif,
thanx for your reply. It is hard to share this code because is property of the company I work for.
I think I did find something though.
2023-12-14 11:07:24 DROP UDP XX.XX.XXX.XX 224.0.0.251 5353 5353 904 - - - - - - - RECEIVE
2023-12-14 11:07:24 DROP UDP XX.XX.XXX.XX 224.0.0.251 5353 5353 286 - - - - - - - RECEIVE
I think my setting for seeing the blocked packages with procmon was wrong I ended up with searching for the firewall log file the name of the file in windows is:  pfirewall.log it is located at this location c:\Windows\System32\Logfiles. I did replace the lp number with X characters for security reasons. The IP is the IP from the cRIO
If anyone knows the correct filter for procesmonitor to view the dropped packages please let me know!
I am at home now, tomorrow I will have another try. I think I need to open these ports is this correct ?
(1,656 Views)
