Error -2915 when attempting to Integrate Visual SourceSafe
I amtrying to integrate VSS so that, from the VI, I could Check-In/Check-Out the files....
DOK
(3,149 Views)
****Message Deleted****
Message Edited by muks on 05-11-2010 07:13 PM
(3,129 Views)
Hi DeOdderKeith,
Before you do this programmatically, have you tried checking VIs in and out of VSS manually? There's a good guide to using source code control in LabVIEW here. Also, which versions of LabVIEW, VSS, and Windows are you running?
Verne D. // Software R&D // National Instruments
(3,117 Views)
Microsoft Visual SourceSafe Version 6.0
LabView Version 9.0 f2
Windows XP SP3
(3,114 Views)
