Error -2625 Failed to Write File Invoke Node in NI_XML.lvlib:Save.vi
I'm getting this error when doing a certain acquisition with a CoolSnap HQ2. The user defines his paramaters then those paramaters are saved to the file so that they can be easly identified later in the database. The error came to us when we did a test with 4 different parameters. We did: Laser X w/ Filter X ; Laser X w/ Filter Y ; Laser Y w/ Filter X ; Laser Y w/ Filter Y.
The first and third one gets saved without errors but the second and fourth get errors.
Does anyone have an idea what is going on? Here's the vi i'm talking about.
I forgot to mention that Filter Y's attribute name is 593/LP, could the "/" be the cause?
(3,962 Views)
Accepted by topic author GaelC
Found the solution myself. It was indeed the "/" in the name of the filter which caused the problem. I replaced it with a "-" and everything worked 🙂
(3,934 Views)
May I know what is that reference you are talking about.I am also getting same error while saving file with the name "C:\GPIB -  XML Changes Version1 without excel\Products\Integrated VARSPD_FURNB_ING\TestData\29 Nov 2018\sssss___29_11_2018_12_28_05.xml"
Is this the path that creating this error? Please reply to me asap.
K Mahesh
(3,320 Views)
