Error -223767
I am running Labview 8.6, the program I am running have been running for a while with no errors. no change was applied to the program. recently I am getting error -223767 below is the error message:
"error -223767 occurred at DAQmx write digital bool1 line 1 point, 4 possible reasons
internal software error occurred in MIO software please contact national instruments support.
Device : Dev1
Task name: outlet R26"
This error happened multiple times with different task name every time, any idea what is wrong?
Thanks.
(2,459 Views)
Hi there. So this error occurs when the DAQmx drivers have been corrupted. You might have to repair your DAQmx drivers.
http://digital.ni.com/public.nsf/allkb/AC6ED75D3D93375686256E8E00245F0D
This document shows you how. If this does not work, your next best step is to uninstall and reinstall the drivers to clean out the corruption. I hope it works for you!
Ravi A.
National Instruments | Applications Engineer
(2,446 Views)
