Error 2147217833 - Overflow ???
The above error(also enclosed here) is occuring sometimes, inspite the vi runs at times. What does this "overflow" means here??
Any comments please??
(3,625 Views)
This sounds like it could be an Integer Type overflow. Are you sure the number you are trying to insert into the Access table is not too big for that table's field's data type?
(3,620 Views)
John,
You may be right as well. Was using data type of "single", but sometimes runs smoothly for the same rang of data. But thinking that the number of decimal points making the difference. I have changed to "double" at the moment,  looks ok for now, will be watching how it goes.
Thanks for the suggestion.
If you are interested, the latest crash info(lvlog) file is enclosed here`.
(3,616 Views)
Well Parny, good luck! I'll be watching.
(3,595 Views)
