Error-2147024891
Hi!
Anybody know what does this error mean? How can I correct it?
Thank You.
Message 1 of 8
(4,758 Views)
Did you try a search?
Did you try right-clicking on the error cluster and select "Explain Error"?
You did not provide any information as to what you're doing.
Message 2 of 8
(4,753 Views)
The error code description is "General access denied error."
It may have to do with access restriction with a file on your system.  You may want to check datasockets if you use any..
If you're using Active-X, you may want to look at this thread:  http://forums.ni.com/ni/board/message?board.id=170&message.id=231095&query.id=11650#M231095
Also, can you provide a description of what your code does?
RayR
Message 3 of 8
(4,740 Views)
I want to open Multisim in Labview using ActiveX.
Message 4 of 8
(4,724 Views)
It appears to be a problem with permissions to open Multisim.
Are you able to open the application manually (without Labview)?
RayR
Message 5 of 8
(4,711 Views)
Numerous posts by this user regarding MultiSim and LabVIEW. Hard to keep track of which discussion is active anymore.
Message 6 of 8
(4,703 Views)
no kidding..
It would have been easier to figure out what's going on by staying in one thread 😉
Message 7 of 8
(4,681 Views)
Message 8 of 8
(4,678 Views)
