Error -2146797887
SIR/madam
I need the reason for this Error
Error -2146797887 occurred at DataSocket Read in Downloader.vi
This error code is undefined. No one has provided a description for this code, or you might have wired a number that is not an error code to the error code input
Regatds
Sathish
Soliton Technologies,
Bangalore
India
(2,671 Views)
Hi Coimbatore,
Unfortunately there isn't a lot of documenation on this error, but I suspect it means that the URL you are sending to the Datasocket Read is invalid.  I would check that first.  If you are not using a recent version of LabVIEW I would also suggest upgrading if possible as the error handling and Datasocket API have improved in newer versions of LabVIEW (currently at 8.2).
Doug M
For those unfamiliar with NBC's The Office, my icon is NOT a picture of me 🙂
(2,649 Views)
