Error -2146777998 at creating excel file
Hello Together,
for a test device I'm creating an excel file.
sometimes I get the following Error:
from debugging I know, this happens here:
Working solution is to end the Excel Task via the Taskmanager:
is there a way to do this within the program as I'd like to reduce User interaction..
(2,328 Views)
By using the Report Generation Toolkit it works well even if Excel is already open and in use.
An other way is to kill the task with System Exec, as you are doing manually currently.
(2,305 Views)
Hi defaphe,
thanks for the Tip.
I tried the following, but it doesn't work.
Error occurs at the "workbooks""add"
the termination is ok, but again at the "add workbook" the error happens again and the excel Task is still running
so obviously the termination of the excel task does not work
any ideas why:?
(2,278 Views)
even the full path name does not work:
(2,271 Views)
Accepted by topic author WWolf78
You are missing some "". See the snippet below.
(2,262 Views)
damn, always those tiny details which blocks those functions...
with the "" it works!
Thanks!
(2,250 Views)
