Error -20068
I'm trying to fit a circle in a dataset to find its radius (c) and centre (a,b).  I know I could use the fit sphere.vi but I wanted to try this. In fact I used it with the same dataset and it succesfully (and accurately) obtains  both the radius and the center. I've created the equationEq.PNG
and built the fitting vi (Attached) but there's always this -20068 error complaining about the dataset.
Thanks for the help!
Message 1 of 8
(3,292 Views)
Did you look up the Error Message?  [Help, Explain Errors].  It says "Something is NaN, Not a Number".  Look at your formula,  Assume c = 0, which reduces the equation to
Y = sqrt (-(X-a)^2) + b.  Now assume that you plug in a value of X that is different than a.   Do you see a problem, something that might evaluate to "Not a Number"?  [Or, possibly, Not a Real Number?]
Message 2 of 8
(3,259 Views)
Hi Bob,
Thanks for your reply. I understand that. It will always happen when trying to fit a circle with a smaller radius than what the imposed coordinates suggests but how the fit sphere.vi bypasses this problem? The equation of a circle is what it is.
Thanks a lot!
Message 3 of 8
(3,230 Views)
@cobayatron wrote:
Hi Bob,
I understand that. No, you do not. It will always happen when trying to fit a circle with a smaller radius than what the imposed coordinates suggests but how the fit sphere.vi bypasses this problem? The equation of a circle is what it is.
True, but you were not fitting the equation of a circle, which is a quadratic equation!!  Look it up.
Message 4 of 8
(3,217 Views)
Love is in the air! Ok, I'll look it up
Message 5 of 8
(3,209 Views)
The equation of a circle with radius r and center at (a, b) is (x-a)² + (y-b)² = r²,  No square roots here.
Message 6 of 8
(3,165 Views)
Qestit Systems
Certified-LabVIEW-Developer
Message 7 of 8
(3,144 Views)
To get 'r' you need to Square root the whole shebang.
"I put my root beer in a Square cup, now it's just beer."
Qestit Systems
Message 8 of 8
(3,141 Views)
