Error -200361
I am using the USB-6363 to grabe SPI communication. The USB6363 is the slave, the external clock is at 10 Mhz with 64-bit messages sending at a rate of 50 kHz. Everything is working fine. When I try to open a serial port, the SPI grabbing fails on error -200361.
Could someone assist?
(614 Views)
Hi Gabi,
Do you operate the USB-6363 and your (virtual) COMport on the same USB hub?
Have you tried to put them on different USB ports/hubs?
(610 Views)
I tried both options working on the same hub and working on a different hub, it didn't influence the problem.
(606 Views)
