Error-200292
Hello all,
I was trying to generate 2 different waveforms for controlling a 2d galvo scanner and a TTL signal to trigger a line-scan camera simultaneously.
But while the code is running I'm getting the error code "Error-200292"  and the VI stops temporarily. But when I close the error message, it waits for about 2 minutes and gives out a second error code,   "Error code: -1074397150 NI IMAQ Grab Acquire"   and then the vi stops permanently. The camera acquisition works fine until the first error occurs, say if I want to capture 100 images it will go smooth up to 9 images and the first error will be displayed. Once the second error is displayed 91 copies of the second image is created and the vi will be stopped.
Can you please suggest to me how to overcome this problem? Please find attached the VI
Many thanks in advance.
Nijas
(2,148 Views)
Accepted by topic author NIJAS_MOHAMED
What kind of devices you are using?
A possible reason for this error can be that the non development PC is slower and is not pulling data off of the DAQ device fast enough.
In addition you follow the troubleshooting steps  for the camera
(2,034 Views)
