Error-200279 when reading Analog Wfm Nsample
I'm calling the attached VI at least 10x in the main VI and works fine but sometimes it's giving me an error-200279. Can someone please tell me why?
Thank you in advance.
______________
KowdTek
LabVIEW 2009
One Step At A Time, Maybe Two...
(2,638 Views)
Accepted by topic author KowdTek
Your buffer isn't big enough.
You are collecting 20,000 samples per second, but only set it for 2000 samples per channel.  So that is 1/10 second worth of data.  You are reading 1000 samples at a time, so about 1/20th second.  If the loop is running fast enough, you can keep up and won't get an error.
If there is a small delay (perhaps Windows goes off and does something else for 50 or 100 msec.) your buffer will overflow.
I'd suggest eliminating the 2000 constant where you set the samples/channel and try again.  See if it behaves better.
(2,635 Views)
Thanks RavensFan! It works better now..
______________
KowdTek
LabVIEW 2009
(2,615 Views)
