Error 200220
May I ask why do I have error 200220 but I got the correct name of device in Labview and Max. I am using LabVIEW 8.6 and NI DAQmx Base 3.2. When I trying to run the VI in pc, error 200220 pops up. Also, when I enter NI DAQmx Base Task Configuration Utility, there is no detected device. But, in fact, I created a virtual device in max and also connected USB 9162. Does it means that LabVIEW 8.6 or max is not synchronize with NI-DAQmx Base 3.2? The following is my simple programming algorithm as reference.
Thank you for your help.
Message 1 of 1
(3,044 Views)
