Error -200220 with 6062E PCMCIA card + BNC-2110
Hi All,
I have a problem with card 6062E. My LabVIEW version is 2010. As can be seen in attachment MAX is able to find device and its name is "Dev17". Also on LabVIEW side channel control can found this device and channel a0. What is might be wrong my current setup because I'm receiving this error all the time?
I have done some tests on MAX side and channels are measuring voltage in correct way.
Thanks in advance,
-Jim
(2,633 Views)
Accepted by topic author SnowForest
Use DAQmx VIs instead of DAQmx base VIs.
(2,595 Views)
