Error -200217 occurred at DAQmx Start Task.vi:7220001
I am gettiing this error and do not know what to do with it.
(9,782 Views)
You are trying to start your task before you finish setting it up.  This is the second Analog Output that this is happening with.
(9,779 Views)
So are you saying the start task subvi needs to go later in the vi.
(9,777 Views)
Yep.  You shouldn't start your task until you have it fully configured (timing, logging, channels in the task, triggering).
(9,767 Views)
To remove this error, you need to change your temperature unit in degree C from Kelvin.
(8,297 Views)
