Error -200088 append
Hello everyone ,
I am using the PCI 6323 card . Whenever i am calling this attached vi . I got a error as -200088 to append . Cant able to predict what was the issue ?.
Step by step calling this . But while writing issue was there .
note :
I have cleared the tasks in NI MAX and reset the Ni MAX base  for checking .
Message 1 of 18
(3,119 Views)
Hi willcan,
As this seems to be some kind of AE you need to also show the calling mainVI!
Do you initialize the task correctly?
Do you really need this AE-type construct for such a basic implementation of just 3 or 4 DAQmx functions?
The enum should be type-defined, and there should be NO "default" case!
Message 2 of 18
(3,055 Views)
Hi gredw ,
Yes i used the AE . Nothing big deal in main VI . I just called this AE from Main vi .
when ever i used as a normal process like and called this attached VI .. create channel --> start task --> read --> stop --> close
please see attached one . Its nothing new in that .
when ever i used to run a vi " DO Sub write " for single time . Its running without issue .
But called this DO Sub write from main vi means error -200587 was coming
Nothing i reserved that channel . For safety i reset the Max database and reset NI configuration data also .
Deleted the Networks system  and disabled the antivirus .
i cant predict where that channel was allocated or reserved
please advise
Message 3 of 18
(3,029 Views)
Hi willcan,
please advise
I advise to attach your MAIN VI, where you call those subVIs you presented so far! (I already did so in my first reply…)
Btw. the loop in "DO sub write" is Rube-Goldberg as it only iterates once…
Message 4 of 18
(3,023 Views)
Hi gerdw ,
Main Vi comprises of confidential things . that's why   i cant ..sorry..
Even in  DO SUB write .vi itself error was there while during the write operation.
Shall i repair NI DAQ or reset or reinstall ?
Message 5 of 18
(3,015 Views)
Hi willcan,
@willcan wrote:
Hi gerdw ,
Strip down until there are no confidential things included. Or create a test VI which demonstrates the very same problems/errors…
I don't think you need to reinstall DAQmx.
You wrote sometime before it was working as expected!?
Message 6 of 18
(3,010 Views)
Spoiler
Hi gerdw ,
DO Main .vi is simple AE . That itself throwing an error while during the write operation after initialize case .
I am just switching On the relay .
Its need to work in AE right ? that itself issue was there . so only i tried with the DAQ module  reinstall
Attached VI .
error message : Error -200088 DO main.vi <Append>
Thanks in advance !
Message 7 of 18
(2,996 Views)
Hi willcan,
An AE doesn't prevent race conditions, so there might be a "close" call before the "write" call.
Again I ask you to provide the MainVI, which is using this AE!
Message 8 of 18
(2,993 Views)
The following trivial usage of your AE ran without error.   Like GerdW, I think the problem is in the application code you have that calls your AE.   The AE itself is ok.
-Kevin P
Message 9 of 18
(2,983 Views)
In your Initialize state create the task before creating your channels.
Message 10 of 18
(2,980 Views)
