Error-200077 at DAQmx
Hello, my data acquisition card has a problem, as shown. I can't find the program in the question prompt. Can anyone help me?(My data acquisition card is connected to the rising edge count.)
Message 1 of 18
(4,081 Views)
Hi hblin,
what happens when you run your VI in debugging mode with highlighting (and maybe step-by-step execution)? Don't you spot the problem then?
I guess the problem is within the DAQmxTiming functions, maybe the one with "Implicit" mode…
Message 2 of 18
(4,072 Views)
What DAQ card are you using?
Message 3 of 18
(4,055 Views)
usb-6343
Message 4 of 18
(4,049 Views)
I ask because an important piece of information is knowing what the device is.  You could be using a particular device that doesn't have the mode of operation you are trying to set.
What is that constant going into the bottommost subVI?  What does the enum with the crazy little symbols say?
Message 5 of 18
(4,046 Views)
Yes, I stop the program. the problem is in this vi, as following
Message 6 of 18
(4,041 Views)
Hi hblin,
showing an image of an icon is next to useless…
What is the result of the requested debugging actions?
Message 7 of 18
(4,034 Views)
This data acquisition card has been used by our lab before, so it is impossible that the data acquisition card does not support this mode. For the bottommost subVI, what do you mean? refers to which subVI? Is it this?
Message 8 of 18
(4,032 Views)
What does this say?
We can't read that.
Message 9 of 18
(4,027 Views)
It means rising edge. There should be no problem here.
Message 10 of 18
(4,022 Views)
