Error 200022 when using multiple channels
I am getting Error -200022 as shown below.
A "Highlighted Execution" is shown below.  Any help would be great.  Thanks.
(5,644 Views)
Here are the two pictures from above if they were not clear enough.
(5,639 Views)
Did you do a search for that error code or message. It's very common mistake. You simply cannot have multiple tasks for the same resource (i.e. analog input). Use a single task with multiple channels.
(5,624 Views)
The error comes because you are tying to read the battery voltage and battery current using the same moudule.
(4,545 Views)
