Error 2 occurred at C:\Program Files (x86)\National Instruments\LabVIEW 2012\vi.lib\addons\LabJack\ljackuw.llb\EAnalogOut.vi
I keep getting an error about memory being full on the EanalogOut icon-->
LabVIEW:  Memory is full.
NI-488:  No Listeners on the GPIB.
I'm fairly new to LabView so a detailed explanation about this problem and how to fix it would be greatly appreciated.
I'm collecting sulfur dioxide concentration data in a simple spreadsheet and writing it to a file. I would also like to know how to write a header for the column of data that I'm collecting. I've attached my VI that I've written.
Thanks in advance!
(3,251 Views)
Are you getting LabJack errorcode 2 from EAnalogOut.vi?  That means "No LabJack Found":
http://labjack.com/support/u12/users-guide/4.40
Use GetErrorString.vi to interpret U12 errorcodes, as shown in "e function example.vi" among others:
http://labjack.com/support/u12/users-guide/4.19
(3,239 Views)
It's actually a different error. I think I need to reset the memory because after multiple runs the VI will stop functioning and highlight the Analog out. I can manually reset it and it's fine, I just don't want to keep doing that.
Also, any pointers about including headers for the SO2 column?
(3,231 Views)
Do you see the same error with "e function example.vi", or does it run fine?
(3,220 Views)
