Error: 1D array of single
Hi
I used a project that already made to acquire the EEG signal from the Neurosky headset,
(The project taken from the following link: https://forums.ni.com/t5/tkb/articleprintpage/tkb-id/7324/article-id/338).
The program working perfect and I am able to view the signal.
I tried to edit the project so i can send the signal out of my computer using MyRio by putting (MyRio Analog Output block).
I got the following error:
.You have connected two terminals of different types
(The type of the source is 1D array of single[32-bit real(6 digit precision
(The type of the sink is double[64-bit real(15 digit precision
Any help will be appreciated regarding how to solve this error.
(4,284 Views)
Hi sa,
either use a loop around this AO function - or use a different mode of the AO function which accepts an array (like "n samples")…
(4,281 Views)
can you give me more detail about how to do either of the two options you listed. I am a kind of newbie to the LabView.
(4,271 Views)
Accepted by topic author Sa05999
Hi sa,
- Using loops and "autoindexing" is explained in the "Getting started" section in the header of the LabVIEW board…
- The AO function looks like an ExpressVI - usually you can configure them after a double-click…
(4,258 Views)
Thank you for your help, I download  NI High Throughput so I can choose Analog Output (N Samples). The problem was solved, but unfortunately, another problem popped up regarding ThinkGear librarySmiley Sad .
(4,207 Views)
What error are you seeing?
Nick
(4,190 Views)
