Error -1967362038
I created a OPC UA Server via NI OPC Servers where I created my tags. The problem occurs when I create new I/O server and there I create OPC Client. I find server (National Instruments.NIOPCServers.V5) and add it to my project. There, I try to find the server tags but then I receive an error shown below 
From ( In Projects >> OPC >> View I/O Items >> ... ), I can see the tags though..
When I use UaExpert instead of NI OPC Servers then I can't find the whole folder in Labview OPC Client. Any idea what would cause this error?
I'm using windows 10. Labview 2019 32bit, version 19.0.1f1.
Regards
Larry
(2,668 Views)
I really need help with this issue because I can't figure out how to solve this problem. Any advice are welcome!
(2,597 Views)
I am having the same issue  has solution been found to this problem.  Any help would be very much appreciated.
(2,471 Views)
